10 years agoClock gating with enable or not
Here is a n00b question from one which is rusty in VHDL: The statement is not to gate the clock, but is the following considered clock gating? ena is a synchronous enable signal.
proces...
10 years agoOh... I've tried to use template from quartus text editor. perhaps it shoud be verified. What can be in else clause for sync_load???
-- In Altera devices, register signals have a set priority.
-- The HDL design should reflect this priority.
process(<reset>, <aload>, <adata>, <clock_signal>)
begin
-- The asynchronous reset signal has the highest priority
if (<reset> = '0') then
<register_variable> <= '0';
-- Asynchronous load has next-highest priority
elsif (<aload> = '1') then
<register_variable> <= <adata>;
else
-- At a clock edge, if asynchronous signals have not taken priority,
-- respond to the appropriate synchronous signal.
-- Check for synchronous reset, then synchronous load.
-- If none of these takes precedence, update the register output
-- to be the register input.
if (rising_edge(<clock_signal>)) then
if (<clock_enable> = '1') then
if (<synch_reset> = '0') then
elsif (<synch_load> = '1') then
<register_variable> <= <synch_data>;
else
<register_variable> <= <data>;
end if;
end if;
end if;
end if;
end process;
