13 years agocache controller and read-during-write behavior
Hello all,
I'm in the process of writing a simple cache controller. I want this controller to exhibit write-back behavior, i.e. when the cache is being written to by the processor, the controller first snoops the appropriate tag and flags. If the tag and valid flag indicate a hit, then the write data goes straight into cache; if the tag does not indicate a hit, but the location is dirty then the controller first flushes the cache line into memory and then loads the requested cache line so as to produce a hit. This all sounds good, but I've come across a problem I can't seem to shake. As just described, when writing to the cache the controller first needs to check the cache line tag/flags. Obviously, all the block rams of all devices are synchronous, so there will be a one cycle delay before I get back the tag and flags. This would imply the controller will always be only 50% efficient at best (first snoop the tag/flags then write the data). My first solution was to read the tag/flags and write the data on the same clock cycle, and then on the next clock cycle, if the tag/flags indicated a miss, to rewind the operation using some skid buffers and then flush/load cache like usual. This, however, requires that the block ram return the old data on read-during-write operations. But I can't find any dual-port ram options on my target device (Stratix V) that support that setting. It always returns new data! Trying to force the ram to return old data for read-during-write operations via inferrence just results in it placing the ram in logic, which is unacceptable. Does anyone have any suggestions? Thanks.
