Another sld_hub error
I am trying to use NIOS 2 processor in max10 FPGA thus I've been unsuccesful. My project includes a NIOS 2 processor with parallel I/O controlling some LEDS.
This is the error I get when I try to compile the project:
Error (11176): Set_instance_parameter_value: There is no parameter named DESIGN_HASH on instance alt_sld_fab
Error (11176): Alt_sld_fab.: version not allowed for EModuleProperty, must be in {[DESCRIPTION, NAME, VERSION, MODULE_TCL_FILE, MODULE_DIRECTORY, INTERNAL, HIDE_FROM_SOPC, HIDE_FROM_QSYS, HIDE_FROM_QUARTUS, OPAQUE_ADDRESS_MAP, GROUP, AUTHOR, ICON_PATH, DISPLAY_NAME, DATASHEET_URL, TOP_LEVEL_HDL_FILE, TOP_LEVEL_HDL_MODULE, INSTANTIATE_IN_SYSTEM_MODULE, EDITABLE, VALIDATION_CALLBACK, EDITOR_CALLBACK, ELABORATION_CALLBACK, GENERATION_CALLBACK, COMPOSITION_CALLBACK, PARAMETER_UPGRADE_CALLBACK, OUTDATED_IP_FILE, ANALYZE_HDL, STATIC_TOP_LEVEL_MODULE_NAME, FIX_110_VIP_PATH, SUPPORTED_DEVICE_FAMILIES, REPORT_TO_TALKBACK, ALLOW_GREYBOX_GENERATION, SUPPRESS_WARNINGS, STRUCTURAL_COMPOSITION_CALLBACK, NATIVE_INTERPRETER, PREFERRED_SIMULATION_LANGUAGE, REPORT_HIERARCHY, UPGRADEABLE_FROM]}
Error (12154): Can't elaborate inferred hierarchy "sld_hub:auto_hub"
Error: Quartus Prime Analysis & Synthesis was unsuccessful. 3 errors, 4 warnings
Error: Peak virtual memory: 4931 megabytes
Error: Processing ended: Tue Jan 29 14:19:40 2019
Error: Elapsed time: 00:00:33
Error: Total CPU time (on all processors): 00:00:49
Error (293001): Quartus Prime Full Compilation was unsuccessful. 5 errors, 4 warnings
I googled this problem and found out similar forum threads, but nothing fixed my problem.
What should I do?
- Ahmed_H_Intel1
Hi, Can you share with me the QSYS system (Screen Shot) and the top level Quartus project file (screen shot)? It seems you are doing something wrong. BTW it is recommended to start with a Golden top design or a reference design in case of using one of Intel's Dev-Kits. - aakkü
Thanks for your reply.
I used this development board without any golden top file in the past and they all worked fine. I don't know it's the source of my problem. Can you confirm that it's not a licensing problem? I am using the free version.
Here are the files you requested. Should I share the .par file as well?
- aakkü
- Ahmed_H_Intel1
Hi, Thanks for the sharing. It is a very simple design, I can't see a fetal error. Please start with one of our example designs here which will be pre-compiled successfully, you need only to edit it as per your preferences and recompile. https://fpgacloud.intel.com/devstore/platform/?acds_version=16.0&ip_core=NiosII&family=max-10&category=2 For more info please check this: Online training: Basics of Programmable Logic (http://wl.altera.com/education/training/courses/ODSW1005) The Quartus Software Design Series Foundation(http://wl.altera.com/education/training/courses/ODSW1110) The Quartus Software Interactive Tutorial (http://wl.altera.com/education/training/courses/ODSW1050) Regards, Ahmed- aakkü
I tried this example : https://fpgacloud.intel.com/devstore/platform/16.0.0/Standard/nios-ii-on-die-temperature-sensor-max10-de10-lite/ and many others.
I still get the same error. It's an example for the board I am using . I still the the exact same error. I also tried different versions of quartus and even different computer. No change whatsoever.
What should I do?
- Ahmed_H_Intel1
- Ahmed_H_Intel1
Hi, I didn't see any errors when I've created the project, It should be a license issue, Can you use the NIOS e core instead and try?- aakkü
Is there any progress on solving this issue?
- aakkü
unfortunately I also tried that before. There is no change.
What do I try next?
- aakkü
Hello Embedded_guy,
Is there any progress? I've been trying different examples for different FPGA series and I get the same errors.
- Ahmed_H_Intel1
Can you share with me the qpf file? I have everything working fine. - Ahmed_H_Intel1
Even a simplified qpf will be fine, don't reveal your design if you mind.- aakkü
I'm not worried about revaling my design. I'm simply trying to get the processor working.
I'm trying to compile the project the same project you shared (max10_LED) Why do you even want the files? I am getting the same errors which I shared below. I am gonna share entire design files, the only change that I made is changing NIOS/f to NIOS/e, apart from that there is no change.
Error: Quartus Prime Analysis & Synthesis was unsuccessful. 3 errors, 30 warnings
Error: Peak virtual memory: 5095 megabytes
Error: Processing ended: Fri Feb 15 10:04:45 2019
Error: Elapsed time: 00:00:36
Error: Total CPU time (on all processors): 00:01:10
Error (293001): Quartus Prime Full Compilation was unsuccessful. 5 errors, 30 warnings
Can you please focus on the errors I get, I know you don't get any errors.
- Ahmed_H_Intel1
Hi, I've compiled the same project you sent to me and I cannot see any issue, Can you please check your Quartus installation? - Ahmed_H_Intel1
- aakkü
Are you serious? You've been telling me the same thing for a month, that you don't see any errors look at my screenshot. I do get errors that's why I'm here to ask for help.
I tried reinstalling, running different versions and even running it in different computers as I told you before, yet you are just telling me you can run it in your computer. I get that, can you please stop repeating that.
Can you please please please focus on the errros that I get andsuggest me something useful other you telling me that you don't get errors or reinstall.
The error seems to revolve around "alt_sld_fab".
I am patiently, very patiently waiting for your response.
Thanks!
