Another sld_hub error
I tried this example : https://fpgacloud.intel.com/devstore/platform/16.0.0/Standard/nios-ii-on-die-temperature-sensor-max10-de10-lite/ and many others.
I still get the same error. It's an example for the board I am using . I still the the exact same error. I also tried different versions of quartus and even different computer. No change whatsoever.
What should I do?
- Ahmed_H_Intel17 years ago
Here is a "Hello world" project I have created and tested now for MAX 10 using the same IPs in QSYS.
Please check this edit it and then recompile after you add your preferences.
Zip file is here
- aakkü7 years ago
I got the same errors. I tried it in two different quartus versions. 18.1 and 16.0. I still got the same errors.
Error (11176): Set_instance_parameter_value: There is no parameter named DESIGN_HASH on instance alt_sld_fab
Error (11176): Alt_sld_fab.: version not allowed for EModuleProperty, must be in {[DESCRIPTION, NAME, VERSION, MODULE_TCL_FILE, MODULE_DIRECTORY, INTERNAL, HIDE_FROM_SOPC, HIDE_FROM_QSYS, HIDE_FROM_QUARTUS, OPAQUE_ADDRESS_MAP, GROUP, AUTHOR, ICON_PATH, DISPLAY_NAME, DATASHEET_URL, TOP_LEVEL_HDL_FILE, TOP_LEVEL_HDL_MODULE, INSTANTIATE_IN_SYSTEM_MODULE, EDITABLE, VALIDATION_CALLBACK, EDITOR_CALLBACK, ELABORATION_CALLBACK, GENERATION_CALLBACK, COMPOSITION_CALLBACK, PARAMETER_UPGRADE_CALLBACK, OUTDATED_IP_FILE, ANALYZE_HDL, STATIC_TOP_LEVEL_MODULE_NAME, FIX_110_VIP_PATH, SUPPORTED_DEVICE_FAMILIES, REPORT_TO_TALKBACK, ALLOW_GREYBOX_GENERATION, SUPPRESS_WARNINGS, STRUCTURAL_COMPOSITION_CALLBACK, NATIVE_INTERPRETER, PREFERRED_SIMULATION_LANGUAGE, REPORT_HIERARCHY, UPGRADEABLE_FROM]}
Error (12154): Can't elaborate inferred hierarchy "sld_hub:auto_hub"
Error: Quartus Prime Analysis & Synthesis was unsuccessful. 3 errors, 32 warnings
Error: Peak virtual memory: 4934 megabytes
Error: Processing ended: Fri Feb 08 09:45:15 2019
Error: Elapsed time: 00:00:56
Error: Total CPU time (on all processors): 00:01:25
Error (293001): Quartus Prime Full Compilation was unsuccessful. 5 errors, 32 warnings
Can you confirm that it's not a licensing issue? I use the free version. Any other suggestions?
