aakkü
7 years agoAnother sld_hub error
Hello, I am trying to use NIOS 2 processor in max10 FPGA thus I've been unsuccesful. My project includes a NIOS 2 processor with parallel I/O controlling some LEDS. This is the error I get when I t...
aakkü
7 years agoI tried this example : https://fpgacloud.intel.com/devstore/platform/16.0.0/Standard/nios-ii-on-die-temperature-sensor-max10-de10-lite/ and many others.
I still get the same error. It's an example for the board I am using . I still the the exact same error. I also tried different versions of quartus and even different computer. No change whatsoever.
What should I do?
Ahmed_H_Intel1
7 years agoHi,
Here is a "Hello world" project I have created and tested now for MAX 10 using the same IPs in QSYS.
Please check this edit it and then recompile after you add your preferences.
