14 years agoaltera_internal_jtag clock and timing issues
Hi
I'm using Quartus 8.1 with SOPC builder including a NIOS and JTAG UART instantiation. a long time ago I got failing paths in the Timequest analyzer, regarding clocks crossing between my system clock and altera_internal_jtag. back then I simply defined the clock crossing as a false path, the red messages were gone and I was happy.:) lately I got some very strange behavior from the design, function that works fine, stops or behave strangely when I use functions not related to them... in short a very unstable design. today I compiled a design with one of this symptoms, recompiled it with a different seed, and the symptom was gone. so obviously I suspect fitting and timing issues. is there a better way to handle the jtag clock (other then set a false path)? should it be defined in the SOPC builder as a clock? should I use some kind of a bridge between the JTAG UART and the rest of the system? who framed Roger Rabbit? thanks in advance Ron
