14 years ago --- Quote Start --- Why do You need such fast clock? Dream on about having such on FPGA itself. You can only get such fast clock on transceiver block. Check Your FPGA datasheet for Fmax. --- Quote End --- I checked my data sheet, It says that It has three pins allocated for clock 1. 50 Mhz 2. 27Mhz 3. External clock So where could i get my fast clock from Fpga itself.I would like know what is transceiver block. Thanks for your help.
