21 years ago
problem when program is running in IDE
i create a small niosII system. I just want to let my lcd display some simple characters.I use the EP1S40 PRO development board. My niosII system includes a niosII5.0 , a sram as reset memory(1024 K bytes),a on chip ram as exception memory(64 K bytes) ,a simple lcd interface ,a tri-state bridge.The hardware and software are all ok,but when i run in IDE ,
the system give me some error messages as follows. What is the very reason?how to deal with it?
Using cable "USB-Blaster [USB-0]", device 1, instance 0x00
Pausing target processor: OK
Downloading 00100000 ( 0%)
Downloaded 18KB in 0.2s (90.0KB/s)
Verifying 00100000 ( 0%)
Verify failed
Leaving target processor paused
    I have the same problem. If i try to run the programm ("hello world") then i get this message:
    Using cable "USB-Blaster [USB-0]", device 1, instance 0x02
    Processor is already paused
    Reading System ID at address 0x021008C8: verified
    Downloading 02000000 ( 0%)
    Downloaded 21KB in 0.2s (105.0KB/s)
    Verifying 02000000 ( 0%)
    Verify failed
    at the address 0x0200_0000 is the sram.
    If i have after some tries success with the download then i get this message:
    ios2-terminal: Warning: The JTAG cable you are using is not supported for Nios
    nios2-terminal: II systems. You may experience intermittent JTAG communication
    nios2-terminal: failures with this cable. Please use a USB Blaster revision B
    nios2-terminal: cable or another supported cable. Please refer to the file
    nios2-terminal: errata.txt included in the Nios II development kit documents
    nios2-terminal: directory for more information.
    nios2-terminal: connected to hardware target using JTAG UART on cable
    nios2-terminal: "USB-Blaster [USB-0]", device 1, instance 2
    nios2-terminal: (Use the IDE stop button or Ctrl-C to terminate)
    and no "Hello from Nios II!" output in terminal window.
    Before somebody say that i should use a "USB Blaster revision B", i'm using a USB Blaster Rev. B
    You will need to check what the peripheral/memory device at that failed location you have. Most development boards come with reference designs; are you using a reference design provided by the board manufacturer?
    Once I found this error, it was caused by a bad SDRAM configuration, memory write cycles seemed to work OK but verification failed.
    You will also need to check your NIOS Eclipse project debug configuration.
    --- Quote Start ---
    originally posted by aclogic@Aug 2 2005, 04:07 AM
    i have the same problem. if i try to run the programm ("hello world") then i get this message:
    using cable "usb-blaster [usb-0]", device 1, instance 0x02
    processor is already paused
    reading system id at address 0x021008c8: verified
    downloading 02000000 ( 0%)
    downloaded 21kb in 0.2s (105.0kb/s)
    verifying 02000000 ( 0%)
    verify failed
    leaving target processor paused
    if i have after some tries success with the download then i get this message:
    ios2-terminal: warning: the jtag cable you are using is not supported for nios
    nios2-terminal: ii systems. you may experience intermittent jtag communication
    nios2-terminal: failures with this cable. please use a usb blaster revision b
    nios2-terminal: cable or another supported cable. please refer to the file
    nios2-terminal: errata.txt included in the nios ii development kit documents
    nios2-terminal: connected to hardware target using jtag uart on cable
    nios2-terminal: "usb-blaster [usb-0]", device 1, instance 2
    nios2-terminal: (use the ide stop button or ctrl-c to terminate)
    and no "hello from nios ii!" output in terminal window.
    before somebody say that i should use a "usb blaster revision b", i'm using a usb blaster rev. b
    --- Quote End ---
    Check the pin assignments.
    dedicated pins connecting to off-chip components cannot be moved
    or check if you are trying to download to ext_flash (u5)
    you can write but verify fails due to block corruption
    --- Quote Start ---
    originally posted by ppk031000+aug 2 2005, 06:34 pm--><div class='quotetop'>quote (ppk031000 @ aug 2 2005, 06:34 pm)</div>
    --- quote start ---
    <!--quotebegin-aclogic@Aug 2 2005, 04:07 AM
    verify failed
    before somebody say that i should use a "usb blaster revision b", i&#39;m using a usb blaster rev. b
    --- Quote End ---
    you can write but verify fails due to block corruption [/b]
    --- Quote End ---
    hey if it works then check if your stdout is mapped to jtag ?
    in project system library properties
    Hi frinds,
    1, Check your address assignmrnt, and you could use auto assignment! then build it again
    2, I have ever meet a problem, Byte blaster II is not good for debugging, which is always error, But Byte BlasterMV is very good. my experience only for refererce!
    FeiWu
    Sounds like a problem with the hardware design.
    - Check to make sure you have the correct timing for the memory you are targetting.
    - Check to make sure you have the proper board layout for the memory that is giving you problems (traces, shorts, solder balls on the pins, etc...)
    - If you are using a Nios development board make sure Unused I/O are set as input tristate pins
    - Make sure you are meeting timing in your design and have taken offchip timing into consideration
    Those are a few things that pop to mind. If that doesn&#39;t get you through the woods post again and hopefully someone will think of a solution for you.
    Hello all,
    I am re-releasing a custom development board that was running with 5.0(FULL) now with 5.1(Web).
    I get the infamous:
    Verify failed
    Normally, I would also suspect hardware as a first option. However, I switched PCs and re-ran my 5.0(FULL) and my development board is working fine. So Hardware IS NOT ALWAYS A CULPRIT HERE.
    What I did to port 5.0 Full to 5.1(Web)
    1. Delete old NiosII Core 5.0 (Licensed) and insert time-limited 5.1 core(Reset my processorrs characteristics : fast, no tightly coupled memory, etc.)
    2. Loaded Virgin machine with 5.1(Web) , 5.1(Megacores) and NiosII5.1 eval(time-limited)
    3. Had to edit qsf because I had incremental compiles set and Web5.1 does not support.
    So now with 5.1 (Web)
    -Recompile worked fine.
    -Program of device successful
    Run SW
    -SYSID verification okay
    - Get Processor paused message( Verify Failed)
    Any thoughts?
    -Baycool
