21 years agoproblem when program is running in IDE
i create a small niosII system. I just want to let my lcd display some simple characters.I use the EP1S40 PRO development board. My niosII system includes a niosII5.0 , a sram as reset memory(1024 ...
21 years ago --- Quote Start --- originally posted by ppk031000+aug 2 2005, 06:34 pm--><div class='quotetop'>quote (ppk031000 @ aug 2 2005, 06:34 pm)</div>
--- quote start ---
<!--quotebegin-aclogic@Aug 2 2005, 04:07 AM i have the same problem. if i try to run the programm ("hello world") then i get this message:
using cable "usb-blaster [usb-0]", device 1, instance 0x02
processor is already paused
reading system id at address 0x021008c8: verified
downloading 02000000 ( 0%)
downloaded 21kb in 0.2s (105.0kb/s)
verifying 02000000 ( 0%)
verify failed
leaving target processor paused
at the address 0x0200_0000 is the sram.
if i have after some tries success with the download then i get this message:
ios2-terminal: warning: the jtag cable you are using is not supported for nios
nios2-terminal: ii systems. you may experience intermittent jtag communication
nios2-terminal: failures with this cable. please use a usb blaster revision b
nios2-terminal: cable or another supported cable. please refer to the file
nios2-terminal: errata.txt included in the nios ii development kit documents
nios2-terminal: directory for more information.
nios2-terminal: connected to hardware target using jtag uart on cable
nios2-terminal: "usb-blaster [usb-0]", device 1, instance 2
nios2-terminal: (use the ide stop button or ctrl-c to terminate)
and no "hello from nios ii!" output in terminal window.
before somebody say that i should use a "usb blaster revision b", i'm using a usb blaster rev. b --- Quote End --- Check the pin assignments. dedicated pins connecting to off-chip components cannot be moved or check if you are trying to download to ext_flash (u5) you can write but verify fails due to block corruption [/b] --- Quote End --- hey if it works then check if your stdout is mapped to jtag ? in project system library properties
