21 years agoproblem when program is running in IDE
i create a small niosII system. I just want to let my lcd display some simple characters.I use the EP1S40 PRO development board. My niosII system includes a niosII5.0 , a sram as reset memory(1024 ...
20 years agoHello all,
I am re-releasing a custom development board that was running with 5.0(FULL) now with 5.1(Web). I get the infamous: Verify failed Leaving target processor paused Normally, I would also suspect hardware as a first option. However, I switched PCs and re-ran my 5.0(FULL) and my development board is working fine. So Hardware IS NOT ALWAYS A CULPRIT HERE. What I did to port 5.0 Full to 5.1(Web) 1. Delete old NiosII Core 5.0 (Licensed) and insert time-limited 5.1 core(Reset my processorrs characteristics : fast, no tightly coupled memory, etc.) 2. Loaded Virgin machine with 5.1(Web) , 5.1(Megacores) and NiosII5.1 eval(time-limited) 3. Had to edit qsf because I had incremental compiles set and Web5.1 does not support. So now with 5.1 (Web) -Recompile worked fine. -Program of device successful Run SW -SYSID verification okay - Get Processor paused message( Verify Failed) Any thoughts? Thanks, -Baycool
