21 years agoproblem when program is running in IDE
i create a small niosII system. I just want to let my lcd display some simple characters.I use the EP1S40 PRO development board. My niosII system includes a niosII5.0 , a sram as reset memory(1024 ...
20 years agoSounds like a problem with the hardware design.
- Check to make sure you have the correct timing for the memory you are targetting. - Check to make sure you have the proper board layout for the memory that is giving you problems (traces, shorts, solder balls on the pins, etc...) - If you are using a Nios development board make sure Unused I/O are set as input tristate pins - Make sure you are meeting timing in your design and have taken offchip timing into consideration Those are a few things that pop to mind. If that doesn't get you through the woods post again and hopefully someone will think of a solution for you.
