21 years agoproblem when program is running in IDE
i create a small niosII system. I just want to let my lcd display some simple characters.I use the EP1S40 PRO development board. My niosII system includes a niosII5.0 , a sram as reset memory(1024 ...
21 years agoI have the same problem. If i try to run the programm ("hello world") then i get this message:
---- Using cable "USB-Blaster [USB-0]", device 1, instance 0x02 Processor is already paused Reading System ID at address 0x021008C8: verified Downloading 02000000 ( 0%) Downloaded 21KB in 0.2s (105.0KB/s) Verifying 02000000 ( 0%) Verify failed Leaving target processor paused --- at the address 0x0200_0000 is the sram. If i have after some tries success with the download then i get this message: --- ios2-terminal: Warning: The JTAG cable you are using is not supported for Nios nios2-terminal: II systems. You may experience intermittent JTAG communication nios2-terminal: failures with this cable. Please use a USB Blaster revision B nios2-terminal: cable or another supported cable. Please refer to the file nios2-terminal: errata.txt included in the Nios II development kit documents nios2-terminal: directory for more information. nios2-terminal: connected to hardware target using JTAG UART on cable nios2-terminal: "USB-Blaster [USB-0]", device 1, instance 2 nios2-terminal: (Use the IDE stop button or Ctrl-C to terminate) --- and no "Hello from Nios II!" output in terminal window. Before somebody say that i should use a "USB Blaster revision B", i'm using a USB Blaster Rev. B
