Nios-V alt_epcq_controller_write() Problem
I have a flash on my custom board which is MT25QU01G. The flash is connected to Nios-V/g with Epcq Controller. I am trying to erase, write, read sectors from flash. Before write and erase I unlock all sectors and after write and erase I lock all sectors. The problem is that my alt_epcq_controller_write() returns success(0) however it doesn't write to flash memory. I read same data from same place and it is not changed. I also look that memory from memory browser and still nothing changed. I call erase method before each write method since it is nor flash but nothing happens. Could you please help me about the problem.
Balerion
Hi Balerion,
Regading to avl_mem slave:
If you also place avl_mem slave in Peripheral Region, you can use the current altera_epcq_controller.c file as is.
However, you may want to place avl_mem slave in cacheable (non-Peripheral) region to take advantage of the cache for read accesses. In that case, cache maintenance needed for flash memory write operation in Nios V/g system. Here is a code example (= not fully validated) to achieve this attached (please replace the file extension from ".txt" to ".c"). At the end of the alt_epcq_controller_write_block() function, cache flush function call and error checking are added.
ShoH
- ShoH_Altera
Hi Balerion
I'll try to reproduce the issue.
Can you share Quartus version and FPGA device that you are using with?
Sho- Balerion
I'm using Quartus Pro 25.1.1 and My Fpga is Arria-10.
Balerion
- ShoH_Altera
Thanks for the info. I'll check if I can prepare a similar set-up.
Regarding flash controller, are you using Serilal Flash Controller, not Serial Flash Controller II ?
And just to be sure, you are assigning avl_csr address of the flash controller in non-cached address region, right?Regards,
Sho
