yes, I wrote nonsense above. The contents of EPCS is not visible in NIOS address space. It is the epcs-controller located at address 0, which is the restart address. But the problem is still the same.
This is part of my firmware.objdump file:
Sections:
Idx Name Size VMA LMA File off Algn
0 .entry 00000020 00000000 00000000 000000b4 2**5
CONTENTS, ALLOC, LOAD, READONLY, CODE
1 .exceptions 000000cc 00200020 00200020 000001b0 2**2
2 .text 00022d44 002000ec 002000ec 0000027c 2**2
3 .rodata 00017be0 00222e30 00222e30 00022fc0 2**2
CONTENTS, ALLOC, LOAD, READONLY, DATA
4 .rwdata 00002ebc 0023aa10 0023aa10 0003aba0 2**2
CONTENTS, ALLOC, LOAD, DATA, SMALL_DATA
5 .bss 00010280 0023d8cc 0023d8cc 0003da5c 2**2
ALLOC, SMALL_DATA
6 .epcs_controller 00000000 00000020 00000020 0003da5c 2**0
There is a section .entry located at 0x00000000 (the epcs-controller base address). All firmware is placed in SRAM (base = 0x00200000).
SYMBOL TABLE:
00000000 l d .entry 00000000
00200020 l d .exceptions 00000000
002000ec l d .text 00000000
00222e30 l d .rodata 00000000
0023aa10 l d .rwdata 00000000
0023d8cc l d .bss 00000000
00000020 l d .epcs_controller 00000000
and here is the code placed in section .entry, linked to address 0:
Disassembly of section .entry:
00000000 <__reset>:
*/# if NIOS2_ICACHE_SIZE > 0x8000
movhi r2, %hi(NIOS2_ICACHE_SIZE)# else
movui r2, NIOS2_ICACHE_SIZE
0: 00810014 movui r2,1024# endif
0:
initi r2
4: 1001483a initi r2
addi r2, r2, -NIOS2_ICACHE_LINE_SIZE
8: 10bff804 addi r2,r2,-32
bgt r2, zero, 0b
c: 00bffd16 blt zero,r2,4 <__alt_mem_epcs_controller+0x4>
1:
This is the code at the restart address, linked automatically to my firmware. So the first dword at address 0 should be: 0x00810014. But when I start debugger without loading software, I can read a memory map at address 0 but find the code of the boot-copier 'epcs_controller_boot_rom.hex'. The code of this <__reset> function above in section .entry can be found at the start of the firmware placed in EPCS behind the FPGA configuration.
So the debugger expects this __reset-code at address 0 where the boot-copier resides in ROM. Perhaps this __reset-code is position independent and therefore also linked to address 0 ?
I'm a little bit confused what happens. Anybody else ?
Explanations welcome.
Mike
