21 years agoNios 2 IDE download verification error
Downloading 00800020 ( 0%) Downloading 00810000 (85%) Downloaded 75KB in 1.6s (46.8KB/s) Verifying 00800020 ( 0%) Verify failed Leaving target processor paused ...
20 years agoHello all,
This is an old post but this thread seems very relevant to my topic I am re-releasing a custom development board that was running with 5.0(FULL) now with 5.1(Web). I get the infamous: Verify failed Leaving target processor paused Normally, I would also suspect hardware as a first option. However, I switched PCs and re-ran my 5.0(FULL) and my development board is working fine. So Hardware IS NOT ALWAYS A CULPRIT HERE, atleast it does not seem that way in my case. As an extra note, I did have to fiddle with SOPC again so I could have in theory screwed up the hardware. So, in order to make sure I did not do anything wrong I stepped through my port carefully a couple of times. What I did to port 5.0 Full to 5.1(Web) 1. Delete old NiosII Core 5.0 (Licensed) and insert time-limited 5.1 core(Reset my processorrs characteristics : fast, no tightly coupled memory, etc.) 2. Loaded Virgin machine with 5.1(Web) , 5.1(Megacores) and NiosII5.1 eval(time-limited) 3. Had to edit qsf because I had incremental compiles set and Web5.1 does not support. So now with 5.1 (Web) -Recompile worked fine. -Program of device successful Run SW -SYSID verification okay - Get Processor paused message( Verify Failed) Any thoughts? It is very confusing and frustrating to have the 5.0 Full stuff working with no verify failed and have the 5.1 Web fail on the same board! Thanks, -Baycool
