21 years agoNios 2 IDE download verification error
Downloading 00800020 ( 0%) Downloading 00810000 (85%) Downloaded 75KB in 1.6s (46.8KB/s) Verifying 00800020 ( 0%) Verify failed Leaving target processor paused ...
21 years agoMike,
Be sure you're not targeting the EPCS for any code in the IDE. You should locate your code in volatile memory. If you are (already), and you're setting your reset vector to the EPCS controller's onchip memory, then I think you may have discovered a bug... Cheers, - slacker
