dim1's avatar
dim1
7 months ago
LPDDR4 not available in NIOSV/g linker script - Agilex-5, Quartus 26.1 Pro
I have a simple design for Agilex 5, using NIOS V/g and EMIF IP with LPDDR4 memory.
I have the NIOS V instruction and data manager ports connected to the EMIF IP. Design compiles Ok. But when I create a BSP, in the linker section, there is not a memory device for the LPDDR4.
In this thread, a similar problem seems to be mentioned - issue-with-bsp-creation-for-nios-vm-using-lpddr4-on-agilex-5-quartus-24-1--24-3
Does it mean that Address Span Extender IP must be used in order to have the LPDDR4 show in the linker script section, as an available memory device?
  • Hi dim1​
    Got it.
    (This may come rather late for you, sorry about that. But I believe you will be interested in this new findings.)
    There is another workaround for the Agilex 5 & 3 EMIF IP involving the isMemoryDevice agent information.
    You may refer to this KDB.
    Unlike the Add Memory Device workaround, this one is tied to QSYS. As such, isMemoryDevice workaround (repeat per new QSYS) is less repetitive compared Add Memory Device workaround (repeat per new BSP).
    Besides that, the isMemoryDevice workaround fixes the problem from the roots in Platform Designer. Thus, the subsequent BSP Editor will work seamlessly (the experience of EMIF IP in BSP Editor will be akin to a OCRAM IP).
    Liang Yu
  • Hi dim1​
    Yes, you are correct that it is the same problem. Reassure that it is resolved in Quartus Prime 26.1.1 Pro.
    (Your post arrived first, while I am still preparing the KDB)
    Not exactly.
    1. In the linked post, the user is connecting a 4GB 32-bit processor address map to a larger EMIF, such as 8GB. Minus 2 GB for other peripherals, you are left with 2GB processor address map to 8GB EMIF.
      So, they need to connect a Address Span Extender IP between the processor & EMIF IP.
    2. However, the Address Span Extender IP is still affected by this "no EMIF" issue in BSP Linker.
      So, the workaround is to manually add the EMIF + ASE into BSP Linker.
    They are two separate issues in a single post.
    For your design,
    1. Your EMIF is able to fit inside the remaining 2GB 32-bit processor address map. No ASE IP is needed here.
    2. The EMIF IP is affected by the "no EMIF" issue in the BSP Linker. Currently, the workaround is to manually add the EMIF into BSP Linker.
      Reference (Replace ASE IP as EMIF IP, and follow the same steps):
      https://docs.altera.com/r/docs/726952/26.1/nios-v-embedded-processor-design-handbook/defining-address-span-extender-linker-memory-device
    Liang Yu
    • dim1's avatar
      dim1
      Hello Liang Yu,
      Thank you for your reply. Will try Quartus Prime 26.1.1 Pro once it is available.
      D.
      • dim1's avatar
        dim1
        Hello Liang Yu,
        So I tried to manually add linker memory device, following the steps in the link you provided. Unfortunately, it does not work. What happens is, a second, duplicate device is created, and still not accessible for creating linker regions, section mappings etc.
        Here is how the memory map looks originally. The EMIF IP is shown as lpddr4_s0_axi4:
        I add a new Memory Device, with name lpddr4_s0_axi4,  Base Address 0 and Size 0x80000000.
        This results in the following Memory Map:
        Notice how now there are two lpddr4_s0_axi4 devices, and neither one of them is usable in the BSP Linker Script.
        Please advise.
        Thank you,
        D.
  • dim1's avatar
    dim1
    Never mind. It actually works, even though it shows two devices with the same name.
    Thank you,
    D.
    • LiangYuG_Altera's avatar
      LiangYuG_Altera
      Hi dim1​
      Got it.
      Liang Yu
      • dim1's avatar
        dim1
        Hello Liang Yu,
        The QSYS workaround is simpler, and resolved the issue.
        Thank you!
        D.
