19 years ago
FrameBuffer problem
hi hippo:
I try to test the FrameBuffer example as your setp,but,the system cann't be
generated.Could you give me the succuess project which can run the framebuffer!
Thanks!! My EMAIL:[email protected]
    --- Quote Start ---
    originally posted by liuxiaoping@Mar 30 2007, 04:12 AM
    hi hippo:
    i try to test the framebuffer example as your setp,but,the system cann't be
    generated.could you give me the succuess project which can run the framebuffer!
    thanks!! my email:[email protected]
    <div align='right'><{post_snapback}> (index.php?act=findpost&pid=22659)
    --- quote end ---
    --- Quote End ---
    to hippo
    I try out to test the FrameBuffer example for days,but,there are always some problems,Could you give me your project which can run the framebuffer!So i can find my problem! Thank you very much!!My EMAIL:[email protected]
    There may be some problem about the ps2 component when i generate the system_0.ptf.and i use the Quartus II 5.0.below is the error:
    # 2007.04.02 09:42:00 (*) Running Generator Program for VGA_0
    # 2007.04.02 09:42:03 (*) Running Generator Program for ps2_0
    ERROR:
    In object &#39;&#39; of class e_port: can&#39;t access `vhdl_record_type&#39; field
    known fields are:
    _AUTOLOAD_ACCEPT_ALL
    __is_inout
    _creation_history
    _direction
    _export
    _negated
    _never_export
    _object_list
    _parent_set
    _project_set
    _ptf_written
    _signal_list
    comment
    copied
    declare_one_bit_as_std_logic_vector
    default_value
    depth
    indent
    isa_dummy
    name
    paragraph
    trimmed
    type
    vhdl_declare_only_type
    vhdl_default
    width
    known pointers are:
    _parent
    _project
    keys:
    _permitted
    _pointers
    by the way, this object is a dummy
    Error: Generator program
    for module &#39;ps2_0&#39; did NOT run successfully.
    Where you guys getting this error:
    I tried following the instructions from the wiki http://nioswiki.jot.com/wikihome/operating...ems/framebuffer (http://nioswiki.jot.com/wikihome/operating...ems/framebuffer)
    but I ran into this error when trying to run make in the uClinux-dist/
    arch/nios2nommu/drivers/altfb.c: In function `altfb_probe&#39;:
    arch/nios2nommu/drivers/altfb.c:161: error: `na_vga_controller_0&#39;
    undeclared (first use in this function)
    arch/nios2nommu/drivers/altfb.c:161: error: (Each undeclared
    identifier is reported only once
    arch/nios2nommu/drivers/altfb.c:161: error: for each function it
    appears in.)
    make[2]: *** [arch/nios2nommu/drivers/altfb.o] Error 1
    make[1]: *** [arch/nios2nommu/drivers] Error 2
    Do you have the vga_controller_0 hardware in your SoPC Builder system? The software# def&#39;s are telling you that you need it. The Wiki should tell you where you can find it. If not, a quick search through the forum should yield results.
    Cheers, and Good luck!
    - slacker
    fs/buffer.c: In function `__find_get_block_slow&#39;:
    fs/buffer.c:292: warning: long unsigned int format, size_t arg (arg 3)
    LD fs/built-in.o
    CC drivers/char/tty_io.o
    In file included from include/linux/selection.h:11,
    from drivers/char/tty_io.c:103:
    include/linux/vt_buffer.h:18:21: asm/vga.h: No such file or directory
    make[3]: *** [drivers/char/tty_io.o] &#38169;&#35823; 1
    make[2]: *** [drivers/char] &#38169;&#35823; 2
    make[1]: *** [drivers] &#38169;&#35823; 2
    make[1]: Leaving directory `/home/nios/download/uClinux-dist/linux-2.6.x&#39;
    make: *** [linux] &#38169;&#35823; 1
    --- Quote Start ---
    originally posted by feng8126@Apr 2 2007, 07:53 PM
    where you guys getting this error:
    i tried following the instructions from the wiki http://nioswiki.jot.com/wikihome/operating...ems/framebuffer (http://nioswiki.jot.com/wikihome/operating...ems/framebuffer)
    but i ran into this error when trying to run make in the uclinux-dist/
    fs/buffer.c: in function `__find_get_block_slow&#39;:
    ld fs/built-in.o
    cc drivers/char/tty_io.o
    in file included from include/linux/selection.h:11,
    include/linux/vt_buffer.h:18:21: asm/vga.h: no such file or directory
    make[1]: leaving directory `/home/nios/download/uclinux-dist/linux-2.6.x&#39;
    <div align='right'><{post_snapback}> (index.php?act=findpost&pid=22731)
    --- quote end ---
    --- Quote End ---
    You must disable these two console,
    Device Drivers --> Graphics support --->
    Console display driver support --->
    [ ] VGA text console
    < > Framebuffer Console support
