19 years agoFrameBuffer problem
hi hippo: I try to test the FrameBuffer example as your setp,but,the system cann't be generated.Could you give me the succuess project which can run the framebuffer! ...
19 years ago --- Quote Start --- originally posted by feng8126@Apr 2 2007, 07:53 PM where you guys getting this error:
i tried following the instructions from the wiki http://nioswiki.jot.com/wikihome/operating...ems/framebuffer (http://nioswiki.jot.com/wikihome/operating...ems/framebuffer)
but i ran into this error when trying to run make in the uclinux-dist/
fs/buffer.c: in function `__find_get_block_slow':
fs/buffer.c:292: warning: long unsigned int format, size_t arg (arg 3)
ld fs/built-in.o
cc drivers/char/tty_io.o
in file included from include/linux/selection.h:11,
from drivers/char/tty_io.c:103:
include/linux/vt_buffer.h:18:21: asm/vga.h: no such file or directory
make[3]: *** [drivers/char/tty_io.o] 错误 1
make[2]: *** [drivers/char] 错误 2
make[1]: *** [drivers] 错误 2
make[1]: leaving directory `/home/nios/download/uclinux-dist/linux-2.6.x'
make: *** [linux] 错误 1
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=22731)
--- quote end ---
--- Quote End --- You must disable these two console, Device Drivers --> Graphics support ---> Console display driver support ---> [ ] VGA text console < > Framebuffer Console support
