19 years agoFrameBuffer problem
hi hippo: I try to test the FrameBuffer example as your setp,but,the system cann't be generated.Could you give me the succuess project which can run the framebuffer! ...
19 years agoWhere you guys getting this error:
I tried following the instructions from the wiki http://nioswiki.jot.com/wikihome/operating...ems/framebuffer (http://nioswiki.jot.com/wikihome/operating...ems/framebuffer) but I ran into this error when trying to run make in the uClinux-dist/ arch/nios2nommu/drivers/altfb.c: In function `altfb_probe': arch/nios2nommu/drivers/altfb.c:161: error: `na_vga_controller_0' undeclared (first use in this function) arch/nios2nommu/drivers/altfb.c:161: error: (Each undeclared identifier is reported only once arch/nios2nommu/drivers/altfb.c:161: error: for each function it appears in.) make[2]: *** [arch/nios2nommu/drivers/altfb.o] Error 1 make[1]: *** [arch/nios2nommu/drivers] Error 2
