19 years agoFrameBuffer problem
hi hippo: I try to test the FrameBuffer example as your setp,but,the system cann't be generated.Could you give me the succuess project which can run the framebuffer! ...
19 years agoDo you have the vga_controller_0 hardware in your SoPC Builder system? The software# def's are telling you that you need it. The Wiki should tell you where you can find it. If not, a quick search through the forum should yield results.
Cheers, and Good luck! - slacker
