19 years agoFrameBuffer problem
hi hippo: I try to test the FrameBuffer example as your setp,but,the system cann't be generated.Could you give me the succuess project which can run the framebuffer! ...
19 years agoThere may be some problem about the ps2 component when i generate the system_0.ptf.and i use the Quartus II 5.0.below is the error:
# 2007.04.02 09:42:00 (*) Running Generator Program for VGA_0 # 2007.04.02 09:42:03 (*) Running Generator Program for ps2_0 ERROR: In object '' of class e_port: can't access `vhdl_record_type' field known fields are: _AUTOLOAD_ACCEPT_ALL __is_inout _creation_history _direction _export _negated _never_export _object_list _parent_set _project_set _ptf_written _signal_list comment copied declare_one_bit_as_std_logic_vector default_value depth indent isa_dummy name paragraph trimmed type vhdl_declare_only_type vhdl_default width known pointers are: _parent _project keys: _AUTOLOAD_ACCEPT_ALL _permitted _pointers by the way, this object is a dummy Error: Generator program for module 'ps2_0' did NOT run successfully.
