Hi tns1,
> When I do a mw.b for the memory from 0x800000 to 0x9D0000, u-boot crashes (locks)
> apparently because I am writing over some parts it is actively using.
Yes, you're overwriting the stack and the heap.
> First, I see three long words at 0x800020 that I verified with objdump are the trampoline
> instructions you mentioned, but writing over them causes u-boot to either reset, lockup or
> stop working correctly (depends on which one I write over).
If this is the case, your exception address is probably 0x800020. When the timer interrupt
fires and the exception is taken, the core executes corrupted code.
> Also my <myboard>.h file I created defines CFG_EXCEPTION_ADDR to be x900020. Isn't this
> where the trampoline should be?
There are two critical macros that must be correct in your config file: CFG_RESET_ADDR and
CFG_EXCEPTION_ADDR. These _must_ match your hardware configuration (cpu settings in SOPC builder).
The u-boot build process is not very sophisticated -- this is good and bad. The good part is that it's
simple -- you only need a shell and the cross-development tools to build it -- no interactions with an
IDE, etc -- you can edit & control the whole process with a text editor. The bad part is, well ...
it's simple ;-) so it won't automagically update the config file for you (or warn you) when your config
file doesn't match your actual hardware.
> If I understand the trampoline, it is only using during relocation, and it should't matter what
> happens to that memory afterwards.
Correct. The trampoline gets copied to CFG_EXCEPTION_ADDR when u-boot relocates itself.
This allows u-boot to stored at the reset address (e.g. flash) or any other arbitrary address.
When u-boot begins execution, it copies itself to TEXT_BASE (ram) and jumps to the relocated
u-boot image. After a few more initializations (e.g. clearing bss, etc), u-boot checks to see if the
trampoline is at the proper exception address. If it's not, it copies the trampoline to
CFG_EXCEPTION_ADDR. The trampoline code does nothing more than jump to u-boot's
exception handler.
NOTE: In some cases, the trampoline does not need to be copied. This would be the case
when TEXT_BASE is set to the exception address minus 0x0020 -- since the trampoline code is
conveniently located at the start address + 0x0020 it's already where it needs to be.
> If I change the first three to 0x900000, 0x800000, 0x800020 I get more consistent behavior,
Yes, this makes sense. This would indicate that your actual hardware configuration has the
exception address set to 0x80_0020. BTW: the "irqinfo" command shows the timer interrupt
count. The count should be incrementing if everything is operating ok.
> but I still cant use the lower memory.
I had a similar problem since I mapped the low-end of SDRAM into a PCI window. When the
host cleared the memory, my core would basically lock up once the timer interrupt fired.
(It would simply execute jmp 0). The solution was to define a small section of on-chip
RAM (0x40 bytes) and set the exception address to offset 0x20 in this memory. This kept
SOPC builder happy, and prevented the host from trashing my interrupts ;-)
> I have been unable to use u-boot to download an image of itself for flashing because this
> step crashes.
I believe this is all related -- the downloaded image is probably corrupting the trampoline,
the heap, or the stack. Based on your ealier comments, you're probably downloading to
0x80_0000 for subsequent copy into flash. This overwrites the trampoline and causes a
crash once the timer interrupt fires.
> My HW has already been fully tested under uCos, and I thought the bootloader functions
> would be a nice addition.
Absolutely ... and I'll do my best to help you get there :-) Once things are stable, I think you'll
really enjoy the more "interesting" features like cramfs/jffs2 support and scripting.
Try the following:
1. Add some on-chip memory and set the exception address to offset 0x20 in the memory.
2. Update you config file with the actual reset/exception addresses from SOPC builder.
3. Rebuild u-boot and strip the elf.
4. Determine the actual u-boot size using objdump and set TEXT_BASE appropriately.
5. Rebuild.
Hope this helps,
--Scott
PS:
> I discovered that once you have built, you cannot copy the source tree to another
> folder and rebuild.
use 'make distclean' prior to copying the source tree -- it should remove any absolute
path references. In the new tree you'll have to make xxx_config again though.
