21 years agoFlash programmer via ethernet
Now that I have ethernet working on my custom board, I'd like to use it to update the board, or at least the flash memory. It is mentioned in the existing board kit docs that board updates via ht...
21 years agoHi tns1,
> I can then try one of: > ==> go 0 ;starts u-boot (the go bug is fixed) > ==> reset ;starts u-boot > (power cycle) ;app starts > ==> go 400000 ;app starts This looks like your reset address is set to 0x40_0000. If 'go 0' and 'reset' correctly starts u-boot (they'er basically the same) ... then a POR with the reset address set to 0 will behave identically. Better double-check your config in SOPC builder ... or better, your ptf file reset_slave/reset_offset. You might want to try flashing the app at 0 and u-boot 0x40_0000 as well. > I should at least get to main_loop() and see some u-boot prompt before > this happens anyway. Agreed ... that's why I don't think the u-boot entry point is being called at all for POR. BTW: Did you move to Quartus 4.2? Or are you still at 4.1? I haven't installed the upgrade yet ... too close to finishing a job ;-) Regards, --Scott
