21 years agoFlash programmer via ethernet
Now that I have ethernet working on my custom board, I'd like to use it to update the board, or at least the flash memory. It is mentioned in the existing board kit docs that board updates via ht...
21 years agoI am sticking with Q4.2 and NiosII1.01 until the dust clears.
SOPC says my reset address is in flash at 0x0 with offset 0x0. The ptf agrees with this. CPU_RESET_ADDRESS is 0x0, reset_slave = "flash/s1"; reset_offset = "0x00000000"; The board is working HW and has displayed no flakeyness while running, but POR is always special. I have created a stripped down project that includes the fs2 module which should allow me to step thru the flashed start.S. This required moving from the e core to the s core so now I have a cache to think about. I am hoping I will see an incorrect jump early in the code to explain this behavior. If the bug only occurs for a real power cycle and not a soft reset, I wont see it in the debugger and will instead have to probe the buses directly. I don't have debug headers for these buses - any signaltap gurus out there? I'll have to make sure to disable cache so all cycles are visible. I'll swap the code locations as you suggest before I dive in.
