21 years agoFlash programmer via ethernet
Now that I have ethernet working on my custom board, I'd like to use it to update the board, or at least the flash memory. It is mentioned in the existing board kit docs that board updates via ht...
21 years agoGreat to hear everything is working now. So now you play with scripting. E.g. --
automatically attempt an NFS download and execute the download on success, otherwise jump into flash ;-) Some notes: > I had originally set CFG_NIOS_TMRMS to 1 thinking I had to match the default hw. The timer stuff can be confusing. The two most important macros are: cfg_nios_tmrms -- number of milliseconds between each timer interrupt. cfg_hz -- the frequency of the timer interrupt. The two are of course redundant, but they're both defined to encourage using the preprocessor for divide/multiply where possible. Sine the Nios timer may be configured with/without the period registers, another macro, cfg_nios_tmrcnt is used. If this macro is defined, the value is written into the timer's period registers when u-boot starts, but is otherwise never referenced. If the macro is not defined, the period registers are never accessed, period. The intent of CFG_NIOS_TMRCNT is to allow users to slow down the interrupt rate when the period is programmable. A 1 ms rate is (normally) overkill in a boot monitor. Since I have a tendency to misplace the decimal point, I use the sleep command to do a sanity check. Try for example, "sleep 10" while looking at your watch ;-) BTW: the timer macros are (indirectly) used by most of the network protocol modules, and by the flash programming code. >I guess it does not matter that I have no cache. Correct, the cache instructions behave as NOP when no cache is configured -- so the bogus instructions do little more than add an unnecessary delay loop when they're left in the code. After downloading, u-boot invalidates the region that was loaded (both data and instruction caches) to ensure everything is coherent.
