21 years agoFlash programmer via ethernet
Now that I have ethernet working on my custom board, I'd like to use it to update the board, or at least the flash memory. It is mentioned in the existing board kit docs that board updates via ht...
21 years agoFor my custom board, I finally got around to putting u-boot and my C application both in the flash. With just u-boot in the flash, it would start up when the board was powered. With both in the flash, my app starts up instead - not what I expected.
My flash is 0x0 to 0x800000. My sram is 0x800000 to 0xA00000. My reset vector is 0x0. My exception vector is 0x800020. u-boot is flashed at 0x0 and linked to run at 0x9d0000. My app image is flashed at 0x400000 and linked with the default NiosII bootstrap to run at 0x800000. I used u-boot to flash both images and verify the locations (not the IDE flash programmer), so I they should be where I think they are. The u-boot boot process seems to be start.S -> board_init() -> main_loop(). As far as I can tell, when I power cycle my board board_init() is never reached and my app is loaded and executed instead. If I erase the section of flash where my app resides, then u-boot begins normally again. I don't see anything in start.S that would explain this behavior. Somehow it is jumping to some location below the app image in flash (0x400000) and above the u-boot image in order to invoke the app bootstrap routine. To test, I load u-boot over jtag and made sure to clear sram before my tests so I am not accidentally re-executing previously loaded code. I can then try one of: ==> go 0 ;starts u-boot (the go bug is fixed) ==> reset ;starts u-boot (power cycle) ;app starts ==> go 400000 ;app starts I see that u-boot has all kinds of options related to autobooting of images, but I don't think they are enabled. I should at least get to main_loop() and see some u-boot prompt before this happens anyway. I've a few more things to try before I gut my project to make room for the hw debugger, but would appreciate any insight.
