21 years agoFlash programmer via ethernet
Now that I have ethernet working on my custom board, I'd like to use it to update the board, or at least the flash memory. It is mentioned in the existing board kit docs that board updates via ht...
21 years agoHi tns1,
> When I do a mw.b for the memory from 0x800000 to 0x9D0000, u-boot crashes (locks) > apparently because I am writing over some parts it is actively using. Yes, you're overwriting the stack and the heap. > First, I see three long words at 0x800020 that I verified with objdump are the trampoline > instructions you mentioned, but writing over them causes u-boot to either reset, lockup or > stop working correctly (depends on which one I write over). If this is the case, your exception address is probably 0x800020. When the timer interrupt fires and the exception is taken, the core executes corrupted code. > Also my <myboard>.h file I created defines CFG_EXCEPTION_ADDR to be x900020. Isn't this > where the trampoline should be? There are two critical macros that must be correct in your config file: CFG_RESET_ADDR and CFG_EXCEPTION_ADDR. These _must_ match your hardware configuration (cpu settings in SOPC builder). The u-boot build process is not very sophisticated -- this is good and bad. The good part is that it's simple -- you only need a shell and the cross-development tools to build it -- no interactions with an IDE, etc -- you can edit & control the whole process with a text editor. The bad part is, well ... it's simple ;-) so it won't automagically update the config file for you (or warn you) when your config file doesn't match your actual hardware. > If I understand the trampoline, it is only using during relocation, and it should't matter what > happens to that memory afterwards. Correct. The trampoline gets copied to CFG_EXCEPTION_ADDR when u-boot relocates itself. This allows u-boot to stored at the reset address (e.g. flash) or any other arbitrary address. When u-boot begins execution, it copies itself to TEXT_BASE (ram) and jumps to the relocated u-boot image. After a few more initializations (e.g. clearing bss, etc), u-boot checks to see if the trampoline is at the proper exception address. If it's not, it copies the trampoline to CFG_EXCEPTION_ADDR. The trampoline code does nothing more than jump to u-boot's exception handler. NOTE: In some cases, the trampoline does not need to be copied. This would be the case when TEXT_BASE is set to the exception address minus 0x0020 -- since the trampoline code is conveniently located at the start address + 0x0020 it's already where it needs to be. > If I change the first three to 0x900000, 0x800000, 0x800020 I get more consistent behavior, Yes, this makes sense. This would indicate that your actual hardware configuration has the exception address set to 0x80_0020. BTW: the "irqinfo" command shows the timer interrupt count. The count should be incrementing if everything is operating ok. > but I still cant use the lower memory. I had a similar problem since I mapped the low-end of SDRAM into a PCI window. When the host cleared the memory, my core would basically lock up once the timer interrupt fired. (It would simply execute jmp 0). The solution was to define a small section of on-chip RAM (0x40 bytes) and set the exception address to offset 0x20 in this memory. This kept SOPC builder happy, and prevented the host from trashing my interrupts ;-) > I have been unable to use u-boot to download an image of itself for flashing because this > step crashes. I believe this is all related -- the downloaded image is probably corrupting the trampoline, the heap, or the stack. Based on your ealier comments, you're probably downloading to 0x80_0000 for subsequent copy into flash. This overwrites the trampoline and causes a crash once the timer interrupt fires. > My HW has already been fully tested under uCos, and I thought the bootloader functions > would be a nice addition. Absolutely ... and I'll do my best to help you get there :-) Once things are stable, I think you'll really enjoy the more "interesting" features like cramfs/jffs2 support and scripting. Try the following: 1. Add some on-chip memory and set the exception address to offset 0x20 in the memory. 2. Update you config file with the actual reset/exception addresses from SOPC builder. 3. Rebuild u-boot and strip the elf. 4. Determine the actual u-boot size using objdump and set TEXT_BASE appropriately. 5. Rebuild. Hope this helps, --Scott PS: > I discovered that once you have built, you cannot copy the source tree to another > folder and rebuild. use 'make distclean' prior to copying the source tree -- it should remove any absolute path references. In the new tree you'll have to make xxx_config again though.
