13 years ago
Ethernet roundtrip time with NicheStack & Nios-II
We are using TSE IP with NichStack, MicroC OS-II on Nios-II. FPGA is running a simple UDP host which echoes all packets it gets from client. The client is a PC running real-time OS and connected to FPGA board via direct, crossover Ethernet cable less than 5 ft. Auto-negotiation sets the speed @ 100 Mb. UDP payload is only 128 bytes. Nios-II is running @ 50 MHz on Cyclone IV. SOPC has SGDMA.
Both sides have no other processign/loading. The board is running in tethered mode (level 1 debuggin on Nios-II), as we are using OpenCore licenses.
We are seeing rather long roundtrip times (in tens of ms) in PC-->FPGA-->PC for each packet. I am looking at AN440 and "Ethernet Acceleration Design", but was wondering if there is seomthing I may be missing here.
What is typical roundtrip time for point-to-point Ethernet, real-time (both sides), closed environment like ours?
-swguy
    I have provided static IP addr in one of the .h files. Will also try hardcoding in the get_ip_addr() call.
    I am using the ref design "Nios-II Ethernet Acceleration" on the Nios-II eval, Stratix-II edition.
    The ref. document for the Marvell 10/100/1000 PHY daughter card (santa cruz connector) says there is some layout issue, which causes the PHY and the DDR clks tied together. PHY clk is derived from SOPC PLL @ 125 MHz and the document says DDR controller must be disabled if you want to run the Ethernet due to this clk issue. It did not make sense to me as the ref design uses the DDR, and the pre-canned binaries seem to work.
    Has anyone dealt with this issue?
    Also trying to use the C2H for checksum. C2H documentation is old and 10.1 sp2 EDS does not have C2H - must use legacy EDS I think. Would C2H for checksum be better choice than custom instruction?
    thanks,
    -swguy
    Daixiwen,
    Fixed the 0.0.0.0 IP issue. It required -DTSE_MY_SYSTEM and a .c file defining it. Also got the round-trip to be under a millisecond by performing few optimization like fast packet mem, deeper cache and /f core with faster MHz.
    The link is auto-negotiating @ 100 mbps. Any idea why it would not go to gigabit? Both sides are capable of doing gigabit and proper cable is used.
    thanks,
    -swguy
    I don't see any reason why the PHY chip wouldn't negotiate a gigabit speed if the other side advertises it. The autonegotiation is independent from the PHY-TSE interface so it should go to gigabit whatever happens on the FPGA side, except if the PHY MDIO registers controlling the gigabit function are modified by the driver. AFAIK the Altera driver doesn't modify those registers.
    Did you try to connect the board to something else than your PC with the embedded OS? Just to see if it isn't an incompatibility between this PC and the Marvel PHY?
    The only other case where I saw a PHY negotiating a lower speed than what it was supposed to was when it was receiving a clock that was slightly out of spec, but I don't think it's the case here.
    I tried the board with Ref design with a PC and it does establish gigabit link. The ref design has Altera's GUI for board test interface.
    The ref design was modified for various optimization and Nios code was changed for UDP server. May be I missed something in the BSP or the TSE driver needs some tweaking?
    -swguy
    When you say "PC" is it a different PC than the one with embedded OS that you tried with your system? If yes can you try this other PC with your design? That will tell if the incompatibility is in your design or something on the PC with the embedded OS.
    If you still see a difference between the two FPGA designs on the same PC, then look for differences between them, especially on the clock and reset signals to the PHY chip. The autonegotiation phase is done automatically by the PHY chip and shouldn't depend on much more from the TSE (except if you are disabling gigabit on purpose from the MDIO registers, but it shouldn't be the case if you are using an unmodified Altera TSE driver).
    Yes, the difference is between two FPGA designs and same PC running the RTOS (same binary on PC). So the PHY/board is capable of gigabit link, but somehow can not establish with my design.
    Good points for clk and reset signals on PHY - will look into it.
    I am not manipulating MDIO at all, but that raises a good point: Can I deliberately tweak MDIO to go for gigabit, just in case? Is there a HAL API for this, if we know TSE's parameters from system.h?
    -swguy
    It's been a while since I experimented with the Marvel PHY. I remember it can be rather picky on it's reset signal. It needs to be low for at least 10 clock cycles (as seen on its XTAL1 pin).
    You can manipulate MDIO through the TSE registers. The best way to do it is to first let the driver initialize itself, and check in the Nios terminal that the PHY was properly detected. Then you know the MDIO interface is working and the correct PHY address has been set in the TSE.
    Then you can use those two macros from <triple_speed_ethernet_regs.h> to read/write the MDIO registers:
    IORD_ALTERA_TSEMAC_MDIO(base, mdio, reg_num)
    IOWR_ALTERA_TSEMAC_MDIO(base, mdio, reg_num, data)
    The altera driver is using the MDIO1 bank in the TSE so you need to set the mdio parameter to 1. base is the TSE base address, as defined in <system.h>.
    The biggest problem with the Marvel PHY is that the datasheet isn't publicly available, and the MDIO registers for Gigabit control aren't standardized. You can nevertheless have a look at MDIO register 09, which is the gigabit control register. If bit 8 is 1 then the PHY will advertize 1000BASE-T half duplex, and if bit 9 is 1 then the PHY will advertize 1000BASE-T full duplex. The MDIO register 0A is the gigabit status register. Those bits can be of interest to you:[list][*]15: 1=MASTER/SLAVE configuration fault detected[*]14:1=local PHY is master, 0= local PHY is slave[*]13:1=Local receiver OK[*]12:1=Remote receiver OK[*]11: 1= link partner is capable of 1000BASE-T full duplex[*]10: 1= link partner is capable of 1000BASE-T half duplex[*]7-0: Idle error count since last read (no roll-over, stops at 0xff)[/list]
