14 years agoEthernet roundtrip time with NicheStack & Nios-II
Hi, We are using TSE IP with NichStack, MicroC OS-II on Nios-II. FPGA is running a simple UDP host which echoes all packets it gets from client. The client is a PC running real-time OS and con...
14 years agoIt's been a while since I experimented with the Marvel PHY. I remember it can be rather picky on it's reset signal. It needs to be low for at least 10 clock cycles (as seen on its XTAL1 pin).
You can manipulate MDIO through the TSE registers. The best way to do it is to first let the driver initialize itself, and check in the Nios terminal that the PHY was properly detected. Then you know the MDIO interface is working and the correct PHY address has been set in the TSE. Then you can use those two macros from <triple_speed_ethernet_regs.h> to read/write the MDIO registers:IORD_ALTERA_TSEMAC_MDIO(base, mdio, reg_num)
IOWR_ALTERA_TSEMAC_MDIO(base, mdio, reg_num, data)The altera driver is using the MDIO1 bank in the TSE so you need to set the mdio parameter to 1. base is the TSE base address, as defined in <system.h>. The biggest problem with the Marvel PHY is that the datasheet isn't publicly available, and the MDIO registers for Gigabit control aren't standardized. You can nevertheless have a look at MDIO register 09, which is the gigabit control register. If bit 8 is 1 then the PHY will advertize 1000BASE-T half duplex, and if bit 9 is 1 then the PHY will advertize 1000BASE-T full duplex. The MDIO register 0A is the gigabit status register. Those bits can be of interest to you:[list][*]15: 1=MASTER/SLAVE configuration fault detected[*]14:1=local PHY is master, 0= local PHY is slave[*]13:1=Local receiver OK[*]12:1=Remote receiver OK[*]11: 1= link partner is capable of 1000BASE-T full duplex[*]10: 1= link partner is capable of 1000BASE-T half duplex[*]7-0: Idle error count since last read (no roll-over, stops at 0xff)[/list]
