14 years agoEthernet roundtrip time with NicheStack & Nios-II
Hi, We are using TSE IP with NichStack, MicroC OS-II on Nios-II. FPGA is running a simple UDP host which echoes all packets it gets from client. The client is a PC running real-time OS and con...
14 years agoWhen you say "PC" is it a different PC than the one with embedded OS that you tried with your system? If yes can you try this other PC with your design? That will tell if the incompatibility is in your design or something on the PC with the embedded OS.
If you still see a difference between the two FPGA designs on the same PC, then look for differences between them, especially on the clock and reset signals to the PHY chip. The autonegotiation phase is done automatically by the PHY chip and shouldn't depend on much more from the TSE (except if you are disabling gigabit on purpose from the MDIO registers, but it shouldn't be the case if you are using an unmodified Altera TSE driver).
