DLiu5
15 days agoWhy the Error Response Slave IP cannot work for Agilex 5 SOC FPGA?
I test the GHRD and corresponding linux image on Terasic DE25-Nano board, however, when I access the FPGA peripheral device, like SW, I use md.l 0x20010060 1 command in U-Boot console, it reports the register value; when I use md.l 0x2fffffff 1 (the H2F ummapped address) or md.l 0x4fffffff 1 (the LWH2F ummapped address), the system will hang up, report Please reset the board!
then I added a Error Response Slave IP and tested, but it still report the same message, then, I need reboot my system every time.
I set the IP as follows:
after this, I added two Error Response Slave IPs in the system, one is for H2F, another is for LWH2F:
Unfortunately, the problem still remains unsolved.
