--- Quote Start ---
First could you clarify? Are you trying to get:
a) (2^n)-1
or
b) 2^(n-1)
I suspect it's a). If not let me know.
module pow_2toN(
input n,
output result
wire shift_reg;
assign shift_reg = {16'd0,16'hffff} << n;
assign result = shift_reg;
endmodule
or...
module pow_2toN(
input n,
output result
genvar i;
generate
for(i=0;i<16;i=i+1) begin : result_assigns
assign result = (i < n) : 1'b1 : 1'b0;
end
endgenerate
endmodule
or...
module pow_2toN(
input n,
output reg result
integer i;
always @* begin
result = 16'd0;
for(i=0;i<16;i=i+1)
if(i<n) result = 1'b1;
end
endmodule
or...
module pow_2toN(
input n,
output reg result
integer i;
always @* begin
result = 16'd1;
for(i=1;i<16;i=i+1)
if(i<=n) result = {result,1'b0};
result = result + 16'hffff;
end
endmodule
We could keep going but I digress. I may have some typos in there. What might be entertaining for you is to try all these variants and see what wildly different compilation results they produce.
Jake
--- Quote End ---
Hi jakobjones
I am sorry
it is (a)
Is this a RTL description?
