16 years agowhat is the circuit of 2^n -1
these is a problem for me,i need some help. how can i use verilog describe 2^n -1 the input interface is input[3:0] n; the output interface is output [15:0] result; i know can u...
16 years agoIf I understood the question (4 to 16 decoder) then MSchmitt's coding is how I would implement this as well. If you don't want the decoder registered then you would write it like this:
reg [15:0] Out_P; always @ (In_N) begin case (In_N) 4'd0 : Out_P = 16'd1; 4'd1 : Out_P = 16'd2; 4'd2 : Out_P = 16'd4; 4'd3 : Out_P = 16'd8; 4'd4 : Out_P = 16'd16; 4'd5 : Out_P = 16'd32; 4'd6 : Out_P = 16'd64; 4'd7 : Out_P = 16'd128; 4'd8 : Out_P = 16'd256; 4'd9 : Out_P = 16'd512; 4'd10 : Out_P = 16'd1024; 4'd11 : Out_P = 16'd2048; 4'd12 : Out_P = 16'd4096; 4'd13 : Out_P = 16'd8192; 4'd14 : Out_P = 16'd16384; 4'd15 : Out_P = 16'd32768; endcase end
