16 years agowhat is the circuit of 2^n -1
these is a problem for me,i need some help. how can i use verilog describe 2^n -1 the input interface is input[3:0] n; the output interface is output [15:0] result; i know can u...
16 years ago --- Quote Start --- First could you clarify? Are you trying to get: a) (2^n)-1 or b) 2^(n-1) I suspect it's a). If not let me know.
module pow_2toN(
input n,
output result
wire shift_reg;
assign shift_reg = {16'd0,16'hffff} << n;
assign result = shift_reg;
endmodule or... module pow_2toN(
input n,
output result
genvar i;
generate
for(i=0;i<16;i=i+1) begin : result_assigns
assign result = (i < n) : 1'b1 : 1'b0;
end
endgenerate
endmodule
input n,
output reg result
integer i;
always @* begin
result = 16'd0;
for(i=0;i<16;i=i+1)
if(i<n) result = 1'b1;
end
endmodule
input n,
output reg result
integer i;
always @* begin
result = 16'd1;
for(i=1;i<16;i=i+1)
if(i<=n) result = {result,1'b0};
result = result + 16'hffff;
end
endmodule
We could keep going but I digress. I may have some typos in there. What might be entertaining for you is to try all these variants and see what wildly different compilation results they produce. Jake --- Quote End --- Hi jakobjones I am sorry it is (a) assign shift_reg = {16'd0,16'hffff} << n; Is this a RTL description?
