Stratix V PCIe HIP not supporting Avalon MM Gen3 x8 I/F
Can anyone say why ?
I have a single EP design using Avalon MM interconnect and across Cyclone IV, Arria V and Stratix V and I want to support Gen3 X1, X4 and X8 on the Stratix V card ... This is a problem to switch to Avalon ST interconnect for one design point .... Any ideas on how to get around this ? Thanks, Bob.21 Replies
If you use the Reference Design Gen3x8 AVMM 256-bit DMA for External DDR3 - Stratix V at http://www.alterawiki.com/wiki/refer...r3_-_stratix_v,
it should works out of the box. Ensure you have reboot the PC after programmed the .sof into FPGA for the PCIe link to establish. - Altera_Forum
Regarding the simulation error, refer to solution:
https://www.altera.com/support/support-resources/knowledge-base/solutions/rd04092014_108.html - Altera_Forum
Thank you. That is going to work.
How about the previous question. - Altera_Forum
I assume your previous question is below:
"I have compiled it as a TOP (with success) and programmed the final sof to a Stratix V PCIe Gen3x8 based board, but I could not get the thing to work (not even "lspci" could recognize the board at start up)." The Gen3_x8_AVMM_256-bit_DMA_for_External_DDR3_-_Stratix_V example design had been tested, it should works out of the box. - Altera_Forum
For your information, there is one set of DIP switch (SW6) on Stratix V dev kit related to PCIe and that is to select the lane width.
Ensure you have set the DIP switches to factory default settings. Refer to Figure 4-2 of 'Stratix V GX FPGA Development Kit User Guide' at https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/ug/ug_svgx_fpga_dev_kit.pdf - Altera_Forum
--- Quote Start --- For your information, there is one set of DIP switch (SW6) on Stratix V dev kit related to PCIe and that is to select the lane width. Ensure you have set the DIP switches to factory default settings. Refer to Figure 4-2 of 'Stratix V GX FPGA Development Kit User Guide' at https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/ug/ug_svgx_fpga_dev_kit.pdf --- Quote End --- Well, a design (encrypted) was successfully programmed in the FPGA on the board and it worked... instead I was indeed referring to an example design (PCIe AVMM DMA) I was not able to send to the same path... so I would not mess with the switches on the board... Anyway, I'll try the DDR3 example as soon as I can... the only gotcha is that everything is Quartus II 14.0v and it does not migrate easily/automatically to 15v, so you gotta stick to 14.0v or manually tweak the Qsys project... Thank you SKBEH for what you give here. - Altera_Forum
Make sure you make changes to the pins. The GX version is different from the GS version. I have tested this design in a GS chip and works fine. You might want to try the design first without the DDR3 since thats another challenge.
-Trukng - Altera_Forum
The issue I have now is that the Stratix V example designs for Gen3x4 or Gen3x8 use a DMA controller and a 64 bit address on the TXS ... I have Cyclone and Arria designs that use NIOS to connect to the TXS port using the CRA translation table configured via NIOS II .
I am not sure how to port the design to Stratix for Gen3x4 or Gen3x8 ... I am currently telling QSYS that the TXS port width is 20 bits and running the Generate to get the Verilog RTL. I then altering the TXS width parameter to 64 bits and concatenating the upper 44 bits to the address into the TXS slave as a hard wired NIOS address -> 64 bit PCIe address translation. Any other ideas on how to port the original design ? - Altera_Forum
Can any one say how I get the CRA tables to support dynamic A2P address translation into a Stratix V gen3x4 or gen3x8 design ... I can only think that I can look at how it is implemented in Cyclone and Arria V and then see how to convert to Stratix V .
So I moved to the gen3x4 design and added NIOS II and some On Chip Memory ... the card works fine so far except for the gen3_led doesn't com on ... when in a gen3 slot the configuration link status indicates a 0x43 which is gen3x4 ... but no gen3_led only the L0_led and the four link leds are on indicating x4 and alive_led flashing ... tomorrow I will confirm gen3x4 operation by adding an analyzer. Almost identical designs that are gen3x8 have the same top_hw.v design where all the LED's are decoded .. the gen3_led is decoded off
assign gen3_speed = tl_cfg_tl_cfg_sts[32:31] == 2'b11; I would like to find the documentation on tl_cfg_tl_cfg_sts but other elements of it like the link width appear to work. With the simulation Generation flipping out on me .... (see the other thread) I am stuck. This vector is generated by altpcie_sv_hip_ast_hip_status_bridge ... that I can't find anything on either. I guess I will try the PCIe ug from Altera. Thanks, Bob.
