11 years agoStratix V PCIe HIP not supporting Avalon MM Gen3 x8 I/F
Can anyone say why ? I have a single EP design using Avalon MM interconnect and across Cyclone IV, Arria V and Stratix V and I want to support Gen3 X1, X4 and X8 on the Stratix V card ... Th...
11 years agoThe issue I have now is that the Stratix V example designs for Gen3x4 or Gen3x8 use a DMA controller and a 64 bit address on the TXS ... I have Cyclone and Arria designs that use NIOS to connect to the TXS port using the CRA translation table configured via NIOS II .
I am not sure how to port the design to Stratix for Gen3x4 or Gen3x8 ... I am currently telling QSYS that the TXS port width is 20 bits and running the Generate to get the Verilog RTL. I then altering the TXS width parameter to 64 bits and concatenating the upper 44 bits to the address into the TXS slave as a hard wired NIOS address -> 64 bit PCIe address translation. Any other ideas on how to port the original design ?
