16 years ago
scaler usage in run time control
I am using vip suite 9.0 and quartus 9.0 for out new project.
I am able to process frames with scaler in static parameters mode there is problem with runtime controle mode.I had following issues
1.I did not found any where a detailed procedure for giving the run time parameters.The vip suite pdf is very vague not detailed in this issue.
2.I could not able to generate the frames using the run time control i could only process single frame that too not correctly
the parameters i am giving are output width 64 and height 32 using the registers
and input width and height as 32x32 using the control packet but the problem is the core is not discarding the extra data if i gave more than 1024 pixels and the output is same size as the input
please help me regarding these issues
ysc
