17 years agoscaler usage in run time control
I am using vip suite 9.0 and quartus 9.0 for out new project. I am able to process frames with scaler in static parameters mode there is problem with runtime controle mode.I had following ...
17 years ago1.ddr2 16 bit wide
2.output resolution is 1080p 3.There two paths one for sdi and another for cvbs,component,dvi,vga the paths will have Deinterlacer,CSC,scaler in second path and CRS and Gamma corrector if required in another path.
