17 years agoscaler usage in run time control
I am using vip suite 9.0 and quartus 9.0 for out new project. I am able to process frames with scaler in static parameters mode there is problem with runtime controle mode.I had following ...
17 years agoIn my project i want to develop video system which can support upto 1920x1080 resolution and I am not using sopc builder.
I want to use the deinterlacer function with 10bit input of 3 colour planed in parallel.I am using ddr2sdram for frame buffering. 1.can u help me regarding the datawidth of ddr2sdram required.Avalon interface usage. 2.I want to use ddr2 high performance memory controller.so how can i interface my 30bit din_data to the ddr2 controller in input 3.can u help me in selecting the avalon master parameters in megawizard for efficient implementation . 4.It would be great help if u had any detailed deinterlacer function application interfacing document regards Ysc
