17 years agoscaler usage in run time control
I am using vip suite 9.0 and quartus 9.0 for out new project. I am able to process frames with scaler in static parameters mode there is problem with runtime controle mode.I had following ...
17 years agoI can run the memory bandwidth calculations for you.
1 - How wide physically is your ddr2 memory? 2 - Are you running 1080p or just 1080i? 3 - It would help if you gave me a description of your entire video processing path (what blocks you have and in what order). Jake
