PCIe Example Design Simulation Failing
Unsing Quartus 18.1 Pro. Generated Gen2x1 or Gen3x4. When compiling in modelsim, I get the following:
# Model Technology ModelSim - Intel FPGA Edition vlog 10.6d Compiler 2018.02 Feb 24 2018
# Start time: 11:31:38 on Nov 06,2018
# vlog -reportprogress 300 -sv ../../../ip/pcie_example_design_tb/pcie_example_design_inst_board_pins_bfm_ip/altera_conduit_bfm_181/sim/pcie_example_design_inst_board_pins_bfm_ip_altera_conduit_bfm_181_o4cgbkq.sv -L altera_common_sv_packages -work altera_conduit_bfm_181
# ** Error: (vlog-7) Failed to open design unit file "../../../ip/pcie_example_design_tb/pcie_example_design_inst_board_pins_bfm_ip/altera_conduit_bfm_181/sim/pcie_example_design_inst_board_pins_bfm_ip_altera_conduit_bfm_181_o4cgbkq.sv" in read mode.
# No such file or directory. (errno = ENOENT)
# End time: 11:31:38 on Nov 06,2018, Elapsed time: 0:00:00
# Errors: 1, Warnings: 0
When checking the path, the file does not exist. Thank you.
- AnandRaj_S_Intel
We acknowledge the issue and will gt back on this,
Also checked with Modelsim 10.6C which gives same error.
Anand Raj Shankar
- SLabe
Based on my investigation, it's probably not due to Modelsim version... It looks more like a qsys generation problem. On that, note that I've tried 17.1 Pro as well with the same outcome. When examining the example design log I do see:
Info: pcie_example_design_inst_board_pins_bfm_ip: "Generating: pcie_example_design_inst_board_pins_bfm_ip_altera_conduit_bfm_181_o4cgbkq"
But the file is nowhere to be found... I've tried running as admin to rule out the permissions, I looked into the temp folder it appears to use but it looks like its hidden in a _db file.
Thanks your help,
- JosephC_Intel
Contributor
Hi Slabe,
We've reported this issue into our bug data entry. Currently under assigning stage. If there is further details obtained, I'll keep you posted.
Joseph
Intel Customer Support
610012
- AndyN
By any chance, are you running on Windows? I had the same (or similar) problem a while ago and it came down to the path length ending up being stupidly long...
- SLabe
Hi Andy, yes Windows. I was actually careful of that and generated the example design at the C:/ level.
Also, there is a pkg file generated at the same depth... so should not be an issue. An Intel FAE colleague also reported that he had observed the same issue...
- User1589943631307909
Hi, SLabe,I got the same simulatioan error and indeed could not generate the simulation file named "pcie_example_design_inst_board_pins_bfm_ip_altera_conduit_bfm_181_o4cgbkq.sv" . OS of my computer is Win10 , version of Quartus Prime Pro Eniton is 18.1 and simulation tool is Questa Sim-64 10.6c. I got error messages as follows, do you know how to fix it now? Thank you very much.
