PCIe Example Design Simulation Failing
Hi Andy, yes Windows. I was actually careful of that and generated the example design at the C:/ level.
Also, there is a pkg file generated at the same depth... so should not be an issue. An Intel FAE colleague also reported that he had observed the same issue...
- User15899436313079095 years ago
Hi, SLabe,I got the same simulatioan error and indeed could not generate the simulation file named "pcie_example_design_inst_board_pins_bfm_ip_altera_conduit_bfm_181_o4cgbkq.sv" . OS of my computer is Win10 , version of Quartus Prime Pro Eniton is 18.1 and simulation tool is Questa Sim-64 10.6c. I got error messages as follows, do you know how to fix it now? Thank you very much.
# vlog -reportprogress 300 -sv ../../../ip/pcie_example_design_tb/pcie_example_design_inst_board_pins_bfm_ip/altera_conduit_bfm_181/sim/pcie_example_design_inst_board_pins_bfm_ip_altera_conduit_bfm_181_o4cgbkq.sv -L altera_common_sv_packages -work altera_conduit_bfm_181
# ** Error: (vlog-7) Failed to open design unit file "../../../ip/pcie_example_design_tb/pcie_example_design_inst_board_pins_bfm_ip/altera_conduit_bfm_181/sim/pcie_example_design_inst_board_pins_bfm_ip_altera_conduit_bfm_181_o4cgbkq.sv" in read mode.
