PCIe Example Design Simulation Failing
Hi Andy, yes Windows. I was actually careful of that and generated the example design at the C:/ level.
Also, there is a pkg file generated at the same depth... so should not be an issue. An Intel FAE colleague also reported that he had observed the same issue...
Hi, SLabe,I got the same simulatioan error and indeed could not generate the simulation file named "pcie_example_design_inst_board_pins_bfm_ip_altera_conduit_bfm_181_o4cgbkq.sv" . OS of my computer is Win10 , version of Quartus Prime Pro Eniton is 18.1 and simulation tool is Questa Sim-64 10.6c. I got error messages as follows, do you know how to fix it now? Thank you very much.
# vlog -reportprogress 300 -sv ../../../ip/pcie_example_design_tb/pcie_example_design_inst_board_pins_bfm_ip/altera_conduit_bfm_181/sim/pcie_example_design_inst_board_pins_bfm_ip_altera_conduit_bfm_181_o4cgbkq.sv -L altera_common_sv_packages -work altera_conduit_bfm_181
# ** Error: (vlog-7) Failed to open design unit file "../../../ip/pcie_example_design_tb/pcie_example_design_inst_board_pins_bfm_ip/altera_conduit_bfm_181/sim/pcie_example_design_inst_board_pins_bfm_ip_altera_conduit_bfm_181_o4cgbkq.sv" in read mode.
