qd0090's avatar
qd0090
6 years ago
LPM DIVIDE latency
hi everyone:
i want to use LPM DIVIDE in max 10, and i use quartus prime 16.1, the clk is 96MHz
but i did not found information about the latency of LPM DIVIDE , so i do not know how many clks should i wait to get the right outputs
  • qd0090's avatar
    qd0090
    this is my lpm divide block
    numer unsigned 21 bits
    denom unsigned 12 bits
    i use signal tab to monitor the latency,
    but i find the latency changes from 2clk(20.8ns) to 5clk (52ns)
    i want to know the max latency
    thanks!
  • KennyT_altera's avatar
    KennyT_altera
    Usually, what we do is use the modelsim to simulate the RTL behavior of the design first.
    Then constrain the design and make sure the timing closed.
    From there, you should be able to see the latency in the Timing reports.
    This latency should not be vary so much. If you look into the modelsim simulation, you will see usually, it take about one cycle of input clock to do the operation.
    • qd0090's avatar
      qd0090
      i test the latency in signaltab, sometimes is 4 clks.
      how to constrain the lpm divide?
    KennyT_altera
    What I try is simulate your design in the rtl simulator vwf files. I dont see any output, can you try it on your side? You can bring out the *vwf files with file -> new -> vwf files.
    https://www.youtube.com/watch?v=RU4LU1nokwg
    You dont need to set the multicycle path for now, after you make sure your rtl simulation behavior, only you set the multicycle.
    KennyT_altera
    We do not receive any response from you to the previous reply that we have provided. Please post a response in the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you with your follow-up questions.
