qd0090
6 years agoLPM DIVIDE latency
hi everyone:
i want to use LPM DIVIDE in max 10, and i use quartus prime 16.1, the clk is 96MHz
but i did not found information about the latency of LPM DIVIDE , so i do not know how many c...
KennyT_altera
6 years agoWhat I try is simulate your design in the rtl simulator vwf files. I dont see any output, can you try it on your side? You can bring out the *vwf files with file -> new -> vwf files.
https://www.youtube.com/watch?v=RU4LU1nokwg
You dont need to set the multicycle path for now, after you make sure your rtl simulation behavior, only you set the multicycle.
