How to handle the Verilog code in VHDL program
The language which I used is VHDL. But the model of DDR2 RAM is only provided Verilog by the vendor. So I need to used verilog code in the VHDL program. Two 16bits DDR2 RAM is connect to use as a 32bits DDR2 RAM.
The code is shown as follow, Is it right for the regular requirement? There maybe something wrong with it as it does seems well in the simulation in Modelsim. The DQ and DQS are alwanys in Hi Z state. Hope someone the help me with this problems. Thanks. Testbence(VHDL) -------------------- component generic_ddr2_sdram_rtl is generic( ROWBITS : integer := 13; DATABITS : integer := 8; COLBITS : integer := 9; BANKBITS : integer := 2 ); port( CK : in std_logic; CK_N : in std_logic; CKE : in std_logic; CS_N : in std_logic; RAS_N : in std_logic; CAS_N : in std_logic; WE_N : in std_logic; DM_RDQS : inout std_logic_vector; BA : in std_logic_vector; ADDR : in std_logic_vector; DQ : inout std_logic_vector; DQS : inout std_logic_vector; dqs_n : inout std_logic_vector; rdqs_n : out std_logic_vector; ODT : in std_logic ); end component generic_ddr2_sdram_rtl; .... verilogmodelGM1 : generic_ddr2_sdram_rtl generic map( ROWBITS => 13, DATABITS => 8, COLBITS => 9, BANKBITS => 2 ) port map ( CK => mem_clk(0), CK_N => mem_clk_n(0), CKE => mem_cke(0), CS_N => mem_cs_n(0), RAS_N => mem_ras_n, CAS_N => mem_cas_n, WE_N => mem_we_n, DM_RDQS => mem_dm(1 downto 0), BA => mem_ba, ADDR => mem_addr(12 downto 0), DQ => mem_dq(15 downto 0), DQS => mem_dqs(1 downto 0), dqs_n => temp1(1 downto 0), rdqs_n => temp2(1 downto 0), ODT => mem_odt(0) ); verilogmodelGM2 : generic_ddr2_sdram_rtl generic map( ROWBITS => 13, DATABITS => 8, COLBITS => 9, BANKBITS => 2 ) port map ( CK => mem_clk(1), CK_N => mem_clk_n(1), CKE => mem_cke(0), CS_N => mem_cs_n(0), RAS_N => mem_ras_n, CAS_N => mem_cas_n, WE_N => mem_we_n, DM_RDQS => mem_dm(3 downto 2), BA => mem_ba, ADDR => mem_addr(12 downto 0), DQ => mem_dq(31 downto 16), DQS => mem_dqs(3 downto 2), dqs_n => temp1(3 downto 2), rdqs_n => temp2(3 downto 2), ODT => mem_odt(0) ); ... Model from vendor(verilog) -------------------- module generic_ddr2_sdram_rtl ( ck, ck_n, cke, cs_n, ras_n, cas_n, we_n, dm_rdqs, ba, addr, dq, dqs, dqs_n, rdqs_n, odt ); ... // Declare Ports input ck; input ck_n; input cke; input cs_n; input ras_n; input cas_n; input we_n; inout [DM_BITS-1:0] dm_rdqs; input [BA_BITS-1:0] ba; input [ADDR_BITS-1:0] addr; inout [DQ_BITS-1:0] dq; inout [DQS_BITS-1:0] dqs; inout [DQS_BITS-1:0] dqs_n; output [DQS_BITS-1:0] rdqs_n; input odt;4 Replies
Did you verify, that the Verilog module is bound by ModelSim? I wonder, if a mixed language ModelSim license is required to use the model.
You could try synthesising the model and producing a gate level VHDL output. It will be slower than a behavioural model but might get you out of your pickle.
There are a few translation tools out there so you might want to look at those too. Have you paid for this model? It might be worth hassling the vendor to produce a VHDL model. Alternatively shoot the person who bought a model that you can't simulate? - Altera_Forum
I guess, it's the Micron model. They are free, but only provided as Verilog.
As far as I remember, Altera has a simple functional DDR2 model included with the DDR2 testbench, but I ddidn't use it and don't know, if it's true VHDL code or a wrapper to a Verilog model. - Altera_Forum
Thank all of kindly helpers. The problem had been solved. Modelsim support the mixed language program exclude the AE version. As FvM said the DDR2 model can be got freely from the vendor but only with the verilog version. The code which is shown is right. Thanks
