robertzab's avatar
robertzab
6 months ago
JESD240B - No license
I am running the ADC on the Arrow DevKit – Agilex 5 E-Series AXE5 Eagle Development Platform.
The converter is the EVAL-AD9695, which uses the JESD204B interface. I initially used ‘Generate Example Design’ and then adapted it for this converter.
However, after making the changes and assigning the pins, I wanted to generate the final output file, but I encountered the following license error:
On the licensing page, I do not see any entry for JESD204B anywhere.
“What can I do to test the design? I previously worked with the Arria 10 GX, and I did not have such problems there.
  • CheepinC_altera's avatar
    CheepinC_altera
    Thank you for filing this case and sharing the details. I appreciate your patience. Please allow me some time to review the information, and I’ll get back to you as soon as possible.
    CheepinC_altera
    Based on the screenshot you shared, it appears that the JESD204B IP license may not be detected in your Quartus environment.
    Could you please help confirm whether the JESD204B‑specific IP license has been obtained after purchase and added to your Quartus license file? If the license has not yet been set up, please let me know and I’d be happy to engage our licensing expert to assist you with enabling the license.
    Feel free to reach out if you have any questions or need further assistance. Thank you.
    • robertzab's avatar
      robertzab
      I am currently in the testing phase on the EVK with the ADC converter, and I assumed that this IP would work in Evaluation Mode with JTAG connected, as it always did before.
      Previously, with the Arria 10 GX, this was exactly how I worked — testing with JTAG connected, and once everything was confirmed to be working properly, the license was purchased.
      Has anything changed in this regard?
        CheepinC_altera
        Thank you for the clarification. I’ll engage our licensing specialist to assist you further.
  • ShengN_altera's avatar
    ShengN_altera
    Please use the Quartus Prime 90-Day Evaluation license. Then make sure enable the Altera FPGA IP Evaluation Mode under Assignments -> Settings -> Compilation Process Settings -> More Settings
