17 years agoHow to handle the Verilog code in VHDL program
The language which I used is VHDL. But the model of DDR2 RAM is only provided Verilog by the vendor. So I need to used verilog code in the VHDL program. Two 16bits DDR2 RAM is connect to use as a 32b...
17 years agoDid you verify, that the Verilog module is bound by ModelSim? I wonder, if a mixed language ModelSim license is required to use the model.
