19 years ago
FFT/IFFT Unity Gain Example
Here is an example that I did a while back when I was playing with the FFT/IFFT core. It was built with DSP Builder 6.1. Also it incorporates the unity gain formula highlighted in the Block floating point Application note.
One thing it highlights is the possibility of using the embedded MATLAB function to generate test vectors for your DSP Builder/ Simulink setup. Hope this helps.
